Hi guys,
Need some advice on colors and specs for my new Spot. For frame color I'm thinking a choice between the two standard colors namely black smoke or deep red unless you guys can convince me custom is worth the extra wait
I should add, in case it affects part choice,that I'm 5'10" 200lbs and I'm looking for an all day trail bike that will be able to deal with the odd drop and jump (nothing major) but would be light enough for burning around my local lake which is fairly flat.
I have already been collecting stuffs which were intended to upgrade my current ride but will now find their way onto my new Spot (although I can replace any of these if they don't suit). Namely:
SRAM PG990 Cassette
SRAM PC991 Hollowpin Chain
SRAM XO Long Cage Rear Mech
SRAM XO Shifters
Bontrager XXX Carbon Riser Bars (Not sure about these, they were for my Trek)
and these little beauties..
Red carbon Marta SL's
Other parts I need and have in mind are:
Wheelset - Hope Hoops (DT Swiss 5.1 on Hope ProII's) Could I get away with 4.2d's?
Fork - RS Pike Air U-Turn
Headset - Chris King. Color ideas?
Seatpost & Stem - Thomson ( I'm 5'10" what length post should I be looking at in the Spot?)
Saddle - Charge Spoon
Bars Something light but strong. Easton Monkeylite, FSA
Crankset - Nothing in mind yet. Is XTR still the way to go for lightness now they have solved the chocolate chainring problem? Would something from one of the niche brands such as FSA or Raceface be ok?
Is there anything else I've forgotten?
I've been agonising on colors for headset and hubs etc. Should I go subtle and get black or go for an accent color (bearing in mind my brake color) like red against a black or white frame?
Ok guys let me know if my build is looking ok and hit me with your suggestions and experiences so I can get this lot ordered.
Looking forward to joining the rest of you Turnerites :thumbsup:
SRAM PG990 Cassette
SRAM XO Shifters
