Hi, just bought Vredestein Bull Lock tires, 26x2.0, folding and have a problem to seat a small section of the folding bead onto the rim.
The tire is sitting in the plain middle, and I can't get it to move and stay against the rim's wall, but only a 3-4" section. The renaming of the tire just sat right in, no problem.
I've tried to pump it up to 60 psi, by slow stages, hoping it would help, then deflate it, and start again, but pinching it and bumping it to try to get the bead to move. No results. Then I deflate it again, run the tire lever all over the bead to try move it closer, it works everywhere excepted the small section where it seems to refuse moving closer to the rim... See the pics.
The pics shows the tire before inflation, then the gap of the bead, then inflated and the difference between the bead seated bad and good...
Any idea ? It's the first time I mess with folding tires, I never had any problem with wire ones since years and I tried everything that would had work with a wired bead tire...
Thanks,
David
Thanks,
David
