These are the two bikes I'm looking to buy..
BMC 5 In. Travel 2007 Trailfox-02 $1,198.00
rear;Rock Shox Ario 2.2 air shock
Fork: Marzocchi 5 Inch travel MZ-I with lock-out, hydraulic oil and coil, preload adjustment
Rear Derailleur: SRAM X7
Front Derailleur: Sram 3.0
Shifters: Sram X7 8-Speed trigger shifters Crankset: TruVativ 175mm Five D, 42/32/22
Bottom Bracket TruVativ Power Spline cartridge Chain: Shimano IG31 8-Speed.
Cassette: Sram PG830 11-32 cassette, 8 speed
Disc Brakes: Hayes Sole hydraulic disc brakes with Mudcutter 7 in. (F), 6 in. (R) rotors.
Handlebar: California Alloy, 31.8mm, 1.5, black
Stem: California Alloy, 31.8mm, 4-bolt, black
Seatpost: Truvativ XR, black
Grips: WTB Weirwolf with Drop Guard End Plugs Headset: Ritchey Logic
Hubs: Shimano M475 32 Hole
Rims: Alex TD-20, black double wall
Tires: Kenda Kinetics 2.35 wire-bead
Saddle: Velo all black with kevlar-type edges
Motobecane 2008 Fantom Comp DS $999.95
Frame TripleActive 4B, 3"/4"/5" Travel - Four Bar Rocker Arm. Gussetted SL 7005 Aluminum (Disc Brake Equipped) SuperSmooth Sealed Cartridge Bearings at critical pivots, replaceable rear derailleur hanger
Fork/Rear Shock RockShox TORA 302 WITH UTURN ADJUSTABLE TRAVEL (85-130MM) TurnKey LOCKOUT /Rockshox Ario 2.2 Air with Rebound and LOCKOUT
Crankset FSA Alpha-Drive 22/32/44T Integrated with BB spindle
Bottom Bracket FSA Powerdrive EXO BB-5000
Pedals FREE Gravity DualStage Clipless/Platform
Front Derailleur Shimano Deore LX
Rear Derailleur Shimano XT long cage
Shifters Shimano Deore LX Rapid Fire 27 speed trigger shift
Cassette/Freewheel Shimano HG cassette 9 speed 11-32T
Chain Z9000 super narrow 9 speed
Hubs Gravity Sealed Bearing for Disc with Quick Release
Spokes Double Butted Stainless steel
Rims WTB SpeedDisc doublewall aluminum
Tires/Tubes Panaracer FireXC PRO 26x2.1 / Presta Valve
Brakes Avid Juicy 3 Hydraulic Disc front and rear, 160mm rotor
Brake Levers Avid Juicy 3 Hydraulic
Headset Ritchey Sealed Bearing threadless 1 1/8 inch
Handlebar Ritchey Rizer SC Butted Aluminum 6061 T6
Stem Ritchey Comp Aluminum threadless
Tape/Grip WTB DualCompound
Saddle WTB SpeedV
Seat Post Ritchey Comp Mountain 31.6mm aluminum
Seat Post Clamp Super Light Aluminum
Saddle WTB SpeedV
