Your skewer is the guilty one...
Those are the guilty ones. The flexion induced is what causes the rotor to get offset.
Don't worry. It happens no matter what your bike or brake is yours. It happens to all of us.
Someone else can tell you how to put the caliper in place to avoid shimming. But I can tell you that something that helps is to make a mark on the axle and the dropouts and make them match anytime you replace your wheel and try to apply the same force anytime you tighten the skewer.
I would think that squeezing the levers would re-set the pads to avoid rubbing if the systems is open but I dunno for real.
That's why I love Avid mechs!!!
