I'm also a bike commuter (15 miles roundtrip) but I do XC style riding on weekends
I am new to FS bikes but have borrowed one on occasion and I must admit I know little about component quality. I did really enjoy a test ride of a fuel 90 large frame bike in a bike store yesterday (I'm 6'1, 195)
please help me decide which is the best deal?
cliff notes:
'03 trek fuel 80 $850
'03 trek fuel 90 $1199
'03 gary fisher sugar 3+ $999
'03 trek liquid 10 $1199
full details:
Frame ZR 9000 aluminum
Fork RockShox Pilot SL
Headset Steel
Rear Shock Fox Float
Rims/Wheels Bontrager Corvair
Hubs Front: aluminum; Rear: Shimano
Spokes 14g stainless-steel
Tires Bontrager Jones AC
Crankset Shimano M440
Chainwheel 44/32/22
Front Derailleur Shimano Deore
Rear Derailleur Shimano Deore
Rear Cogs SRAM 7.0, 9-speed: 11-34
Shifters Shimano Deore
Handlebars Bontrager Crowbar Sport
Stem Bontrager Sport
Brake Levers Aluminum
Brakes Shimano 420, linear-pull
Pedals Shimano M515, clipless
Saddle Bontrager FS2000
Seat Post Bontrager Sport
or
2003 Gary Fisher sugar 3+ $999
Frame Platinum Series ZR9000 aluminum, Genesis Geometry
Fork RockShox Duke XC
Headset Direct connect
Rear Shock Fox Float R
Rims/Wheels Bontrager Select wheelset
Hubs See Rims/Wheels
Spokes See Rims/Wheels
Tires IRC Backcountry, 26 x 2.25
Crankset Bontrager Race
Chainwheel 22/32/44
Bottom Bracket ISIS splined
Chain Shimano
Front Derailleur Shimano Deore LX
Rear Derailleur Shimano XT
Rear Cogs SRAM 7.0, 9-speed: 11-32
Shifters Shimano Deore LX
Tape/Grips Serfas dual-density
Stem Bontrager Select
Brake Levers Avid SD-5
Brakes Avid SD-3, linear-pull
Pedals Shimano M515 clipless
Saddle Titec Ithys Amore
Accessories & Extras Rear shock pump
or...
2003 trek fuel 90 $1199
FRAMESET:
FRAME: ZR 9000 Alloy. World Cup tested. Double butted seamless drawn tubing. Custom butted head tube. Bi-axial downtube. Triangulated Rocker Link. Disc-O disc brake mount. Cold forged replaceable derailleur hanger. Trek Pro Race geometry. Handmade in the USA.
FORK: RockShox Duke XC hydra air, HC2 damping, 30mm upper tubes, external rebound adjust, 80mm travel
REAR SHOCK: Fox Float R air spring, self-adjusting negative spring, rebound adjusting knob, Ni charged
WHEELS:
WHEELS: Bontrager Select: Durable welded rims, machined for smooth braking; OSB rear rim provides good stiffness for any size rider; Hi-Lo ATB rear hub design w/excellent spoke bracing angles for improved lateral wheel rigidity; Cro-Moly skewers; 780 g, 24h front/1045 g, 28h rear
TIRES: Bontrager Jones AC, folding, 26x49/54
COMPONENTS:
SADDLE: Bontrager FS 2000, Cro-Moly rails
SEATPOST: Bontrager Select
HANDLEBARS: Bontrager Crowbar Sport
STEM: Bontrager Select, 10°
HEADSET: AHS 1-1/8" alloy cups, semi cartridge, sealed
DRIVETRAIN:
SHIFTERS: Shimano Deore LX
FRONT DERAILLEUR: Shimano Deore LX
REAR DERAILLEUR: Shimano Deore XT
CRANKSET: Bontrager Race 44/32/22
CASSETTE: SRAM 7.0 11-34, 9spd
OTHER:
BRAKESET: Avid SD3 linear pull
PEDALS: Shimano M515, clipless
or...
2003 trek liquid 10 $1199
FRAMESET:
FRAME: ZR 9000 Alloy. Double butted seamless drawn tubing. Custom butted head tube. Bi-axial downtube. Triangulated Rocker Link design. Black Magic composite seatstays. Liquid geometry adjusts to changing terrain. Handmade in the USA.
FORK: RockShox Psylo C, U-Turn, HC2 damping, travel gradients, 80/125mm travel
REAR SHOCK: Fox Talas R air spring, self-adjusting negative, travel adjust on shock, adjustable rebound
WHEELS:
WHEELS: Bontrager Select Disc: Machined rims welded for strength; OSB rear rim provides good stiffness for any size rider; Hi-Lo ATB rear hub design w/excellent spoke bracing angles for improved lateral wheel rigidity; Cro-Moly skewers; 780 g, 24h front/1045 g, 28h rear
TIRES: IRC TrailBear, folding, 26x2.25"
COMPONENTS:
SEATPOST: Bontrager Sport
STEM: Bontrager Sport, 15°
HEADSET: AHS 1-1/8" semi cartridge, sealed
DRIVETRAIN:
REAR DERAILLEUR: Shimano Deore LX
OTHER:
BRAKESET: Hayes HFX-9, hydraulic disc
cliff notes:
full details:
Headset Steel
Chainwheel 44/32/22
or
Chainwheel 22/32/44
Chain Shimano
or...
FRAMESET:
WHEELS:
COMPONENTS:
DRIVETRAIN:
OTHER:
or...
FRAMESET:
WHEELS:
COMPONENTS:
DRIVETRAIN:
OTHER:
