After several attempts to purchase a bike and finding the majority of my picks out of stock I think I have it narrowed down to one I found in stock. There are three packages and I've narrowed it down to two because I'm not spending the money for package three.
For what it's worth, and the fact I'm just getting started, I'll mostly be trail riding, maybe some down hill stuff if I can get to a park (probably be the slowest guy there), I'd like to try some jumps and maybe learn some tricks, nothing major. I can't afford to break bones and be out of work. I figure I'll get this one and then ride it a couple years and see where I end up.
I've gone through and found all the differences between the two packages. If it's not listed, then it's the same on both bikes. There is basically a $1,000 OTD difference and I'm trying to figure out if it's worth the difference. Prices are $1,717 and $2,674 I think it might be but just not sure.
I'm leaving brand out of it for now, mainly because I think I finally found something in stock and not sure my head can handle more options. Thanks in advance.
Build A $1,717
Build B $2,674
Build A $1,717
Rear Shock | X-Fusion 02 Pro R Large Volume w/ Rebound Adjust, 200x57mm |
Fork | SR Suntour Aion, 27.5", 150mm Travel, Air Spring w/ Rebound Adjust, 35mm Stanction, 1.5" Alloy Taper Steerer, w/ Boost 110x15mm Thru-axle |
Cranks | FSA Comet Direct Mount 1x, w/ 30T Steel Chain Ring |
Bottom Bracket | FSA Sealed Outboard |
Rear Derailleur | Shimano Deore M6000 Shadow Plus, 10 Speed |
Shifter | Shimano Deore M6000, 10 Speed |
Cogset | Shimano HG500 Cassette, 10 Speed, 11-42T |
Chain | KMC X10EL, 10 Speed |
Front Hub | 32h Alloy, Boost 110x15mm Thru-axle, Sealed Cartridge Bearing |
Rear Hub | 32h Alloy, Boost 148x12mm Thru-axle, 4 Sealed Cartridge Bearing, Cassette |
Tires | WTB Vigilante, 27.5x2.3" |
Brakes | Shimano BR-M395 Hydraulic Disc, w/ 180mm Rotors |
Brake Levers | Shimano BL-M425 |
Pedals | DB4L Alloy Platform w/ Replaceable Pins |
Seatpost | DB Alloy Micro Adjust, 31.6mm |
Build B $2,674
Rear Shock | Fox Float DPS EVOL LV, Performance, 3 Position Lever, 200x57mm, 22.2mm Eyelet Width |
Fork | Fox Rhythm 34 27.5", 150mm Travel, Grip Dampener w/Sweep Adjust, 1.5" Tapered Steerer, 110x15mm Thru-axle |
Cranks | Raceface Æffect Cinch w/Steel 30T Direct Mount Narrow Wide |
Bottom Bracket | Raceface Outboard Bearing |
Rear Derailleur | Shimano SLX M7000 Shadow Plus, 11 Speed, GS |
Shifter | Shimano SLX M7000 Shadow Plus, 11 Speed |
Cogset | Shimano SLX M7000 Cassette, 11 Speed, 11-46T |
Chain | KMC X11EL, 11 Speed |
Front Hub | 32h Alloy, Boost 110x15mm Thru-axle, Center Lock, Sealed Cartridge Bearing |
Rear Hub | 32h Alloy, Boost 148x12mm Thru-axle, Center Lock, 5 Sealed Cartridge Bearing, Cassette |
Tires | Maxxis Minion DHF 27.5x2.3" EXO, TLR, Folding / Maxxis Minion DHR II 27.5x2.3" EXO, TLR, Folding |
Brakes | Shimano SLX M7000, w/180mm Front /180mm Rear Rotors |
Brake Levers | Shimano SLX M7000 |
Pedals | DB CNC Platform, Sealed Cartidge Bearing w/Replaceable Pins |
Seatpost | TranzX YSP32FL Internal Dropper, 31.6mm w/Trigger Remote, SM = 125mm, MD = 150mm, LG/XL = 170mm |
