1 - 19 of 19 Posts
Discussion Starter #2
... by way of introduction I am an old guy ...just new to mountain biking. I wish it was the other way around :) I have a 2017 Giant Stance but an thinking of upgrading to this if it makes sense. I tried to pinpoint the model and value but there seems to be quite a few variations of the stump jumper. I am hoping one of the more experienced here can clarify things for me. Thks again
Discussion Starter #7
As far as I can tell, it's a 2020 Stumpjumper ST Alloy 27.5. Someone feel free to correct me if this isn't the case.
FYI, Specialized has a decent Bike Archive section on their website (still there are a ton of models!) that may or may not prove helpful in the future (it's at the bottom of every page, too). (y)
thks napathy .... pretty similar as well eh? only dif I see is where the top and bottom tubes meet at the head tube there isnt the same gap ? :)
The ST in the listing has cheaper components than the link for the Comp you provided. The ST also appears to be 11 speed-
Specs:
FRAMEM5 alloy chassis and rear end, asymmetrical design, 27.5 Trail Geometry, threaded BB, fully enclosed internal cable routing, 12x148mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 130mm of travel
FORKRockShox Recon RL, Solo Air, 42mm offset, rebound adjust, lockout, 15x110mm Boost™ Maxle® Lite thru-axle, 130mm of travel
REAR SHOCKX-Fusion 02 Pro RL, Rx Trail Tune, rebound adjust, lockout 190x42.5mm
FRONT HUBSpecialized, sealed cartridge bearings, 15x110mm spacing, 32h
REAR HUBSpecialized, sealed cartridge bearings, 12x148mm thru-axle, 32h
SPOKESStainless, 14g
RIMSDouble-wall, 27mm internal width, 32H
INNER TUBESPresta, 40mm valve
FRONT TIREButcher, GRID Casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 2.3"
REAR TIREPurgatory, GRID casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 2.3"
CRANKSETSRAM NX, Boost™, direct-mount XSYNC, Powerspline
CHAINRINGS32T
BOTTOM BRACKETSRAM Power Spline
SHIFT LEVERSShimano SLX, 11-speed
REAR DERAILLEURShimano SLX, Shadow Plus, GS cage, 11-speed
CASSETTESunrace, ED Black, 11-speed, 11-46t
CHAINKMC X11, 11-speed w/ Missing Link™
FRONT BRAKETektro Gemini Comp, hydraulic disc, resin pad, 200mm rotor
REAR BRAKETektro Gemini Comp, hydraulic disc, resin pad, 180mm rotor
HANDLEBARSSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm width
GRIPSSpecialized Sip Grip, half-waffle, slip-on
STEMSpecialized, 3D forged alloy, 4-bolt, 7-degree rise
SADDLEBody Geometry Henge Sport, steel rails, 143mm
SEATPOSTAlloy, two-bolt clamp, 34.9mm
SEAT BINDERSpecialized bolt-type, alloy, 38.6mm
PEDALSSpecialized Dirt
Discussion Starter #11
Specs:
CHAINRINGS32T
so Tommy you think its the st alloy 27.5 11 speed then? i saw the bike yesterday but I am a 3 hrs drive away now.. i forgot to count the sprokets on the back add says 12speed but i think I see 11 when i blow up the pic ... cant quite tell 2000 US new then maybe? thks
BOOM goes the dynamite!
Occasionally Cranky
Specs:
CHAINRINGS32T
I don't see any links to any 11spd??? Where'd you get these specs?
Got them from here but it looks like some of the drivetrain (slx vs sx spec) differs from the actual listing that the OP is looking at.
Occasionally Cranky
I see. Go look at the link I gave of the 2020 model which is what I think this is, especially given the manufactured date in late 2019 (after the typical release of MY2020). If I'm wrong, that's fine but the specs match (Recon fork, X-fusion shock, 12spd SX Eagle, Tektro brakes, etc). It all won't make a huge difference in the overall value of a used bike w/no warranty but I'm curious at this point. :)
@ Noapathy- I believe your link was the correct link and mine was wrong. I searched specifically for a 2019 but it looks like the 2020 model that you linked to is the correct one.
Occasionally Cranky
No worries. Now we just gotta know...did OP get the bike? :p
1 - 19 of 19 Posts
