1 - 10 of 10 Posts
I hope I am not the only one who has done this. I bought a used Trek 13 X-cal and thought the fit was fine. I have ridden a few miles on it and love it but am now wanting the large 19" frame. I can buy one on Clist.
Here's my question. How hard is it to switch out the frames on this bike? How many special tools? I am crazy enough to try, but is that too crazy? LBS stated $150.
Most important thing to check is the head tube length on the different frames. If there is a big enough difference and the steer tube was cut short on the old frame, the fork may not be able to be swapped over.
How tall are you and what is your actual inseam?
There are options to give a more comfortable cockpit fit.
First on that bike would be a wider, say 720mm bar. You can get a carbon Bontrager RXL from China off ebay for $50.
Then a 20mm setback seatpost.
Last adjust your stem length, but shorter is better for handling.
I have a 32 inseam, but really long arms. I will start looking into the seat post and wider bar.
Sounds like me, 5'11", 32" inseam, 37" arms, and a longish torso. I tried the 19" and found the fit to be good, but chose a different bike in the end with similar dimensions. I debated this for a while wanting more standover clearance but the smaller frames felt too cramped. I contemplated getting the next smaller size and installing a 20 or 30mm longer stem to compensate for the 1" shorter top tube.
Perhaps the LBS can dig up a slightly longer stem to fit so you can test it out.
The Scott I bought had the stock stem installed inverted so it had a negative rise. Compared to the stock installation it felt better.
Fat-tired Roadie
Try some long stems. If the bike starts nose diving off drops or under braking, it's too small. I think it's actually the position of my torso, not really my hands, that drives the frame length I'm comfortable with.
Stems are only a $15 experiment if you want them to be. And you're likely to need a couple to dial in your next bike if you decide this one just won't work.
Discussion Starter · #9 ·
The seat post stem worked great. I am now spending a lot more time in the saddle. The bike came with two wheelsets and tires. I put the originals back on and now have a set for sale fully set up ready to go. They are more for road/dirt road/gravel. Maybe a hybrid bike set up. Wheels, tires, 10 gear, disc brakes. let me know if you are interested.
1 - 10 of 10 Posts
