Hi everyone
I bought a secondhand Large 02 XCE a few months back which I've slowly built up. It's got the X rocker and Vanilla RC shock which I've had PUSH'd, and I've also found some X-R rockers if an air shock appeals.
So far it's a lovely ride but I'm blowing through the travel (as judged by the position of the rubber bumper on the shock shaft) very easily (6" drops!). I've never felt a hrash bottoming out, though. I need the fourm's advice on what to do!!
I'm 190lbs kitted up with a 550lb coil. This gives the right sag (25%). I've now got the compression turned up to 2/3, but still I'm using all the travel easily.
Is what I'm experiencing nothing to worry about, or do I need a bigger spring? If I need a bigger spring, where can I get one from that will fit? And what length? I'd be interested to know what spring / weight combos people run successfully.
As far as I know, I'll struggle to get anything beyond 110mm fitted on it, and there's not too many 600lb+ 2" springs around that are short enough.
