Do the tapered/chamfered shock washers on the V2 Offering go between the shock and the linkage or on the outside between the bolt head and the linkage.
Seems like they should go inside but they don’t seem to fit or they fall out when you try and slide the shock in place.
If you put them on the outside of the link, under the bolt then the links pinch the top of the shock when tightened making it impossible to turn the rebound knob on the Super Deluxe.
