1 - 3 of 3 Posts
now what?...when trying to remove my wheel the DT Swiss lever unscrewed itself from the axle...the axle is now stuck inside hub/frame
this has got to be the worst design ever...am I missing something here?
Discussion Starter · #2 ·
fyi in case this happens to anyone else...
blue thread locker wasn't strong enough...red thread locker worked to hold the lever in place so that I could unscrew the axle, all good!
Im thinking maybe i cranked the axle too tight? how tight do you crank down the rear axle usually?
El CicloPath!!!!!!!
I crank mine down until it stops. But I can see that when removing, the handle might unscrew from the axel. Didn't know it was designed that way, but I guess that's how it is made. I always thought they were solid all the way thru, but I guess the handle part is screwed on just like hte bolt end. At least it's secure when you have it on.
1 - 3 of 3 Posts
