1 - 5 of 5 Posts
Permanent Noob
Out for a ride today and I started hearing a noise from the rear wheel - a bit of a grinding I'd say. It only happens when I'm coasting, seems to be 2x per wheel revolution, speeds up when I backpedal. When I got back to the house, I removed the rear wheel, I can reproduce the sound with the wheel off, but only when I spin the cassette. I can hear/feel it once per revolution. I can't detect anything when I spin the axle itself.
Haven't done much of my own repairs to date, not to mention troubleshooting. I'm thinking it is an issue in the freehub, but I figured I'd get some opinions from those of you who may have experienced this sort of issue before.
Thanks in advance for whatever help you can give,
Permanent Noob
Discussion Starter · #3 ·
Yeah - don't know how I overlooked that!
It's a Shimano Nexave FH-C501. Came on a cheap set of wheels I use to swap semi-slicks on for street/hardpack riding. Took it over some rougher stuff today, making me think I may have pushed it a bit too far?
Permanent Noob
Discussion Starter · #5 ·
Just finished - it seems as though if not totally eliminated, I've at least cut down on the issue signaifcantly. I may go back in once more just to check the hub adjustment. Moral of the story - print the reference BEFORE you get covered up to your wrist in grease! Secon time around it'll go a lot faster though and I know I can use the practice.
Thanks again for the help!
1 - 5 of 5 Posts
