My rear crossmax SL (on a Rush 1000) leaks very slowly through two of the spoke holes at the rim. It will go from 35 to about 25 psi in a day. I know that it is at two particular spokes because after putting the green Hutchinson air repair in the tire I see that green fluid has leaked around the threads of these two spokes. After putting in the green slime the leak also stops.
My question is: How could this happen? The wheel looks sealed from the inside and separated from the spoke/rim side. And, if green slime makes its way to the spokes, won’t it be all over this sealed area I can’t see making the rim heavier? Can this be fixed?
Tim.
Tim.
