1 - 3 of 3 Posts
· Registered
Are you sure its the frame and not the bottom bracket or crankset? The only part that would creak on a frame are the pivots. Almost everything else is a component whether its the BB, crankset, headset or pedals.
If it is the pivot points, then you could always remove them and use pivot specific grease and see if it helps. If not, then you could order a new bushing set from Turner and replace them.
· Registered
Discussion Starter · #3 ·
Aloha shake.
Yes. Frame pivots. At home in Hawaii I have all the specific tools and grease gun. However I'm out in New Zealand for about another week. I was just hoping someone here in Queenstown might have the tools for Turner. Thanks again.
1 - 3 of 3 Posts
