1 - 6 of 6 Posts
Hi guys/gals I'm in Germany I'm English having a mare with shops here telling me loads of crap I need this ,that I'm riding my bike to hard yeah I no, took it to see what's wrong as I've got a cracking noise when I give it some beanz, I no it's the crank I've got a specialised crosstrail sports disc, the crank is a suntour and the teeth are quite worn I've took of the chain and listened to the bearing and it's a bit noisy, just wanted to no if the shimano deore xt will fit as I can buy it online and have it fitted, just don't wanna get it and get told you have the wrong one it's 27 gears any advice appreciated cheers
Hard to say without seeing it but it sounds like a drivetrain replacement is necessary. Once the chainring is shot, the chain is most likely toast too. If that's toast, I'd replace the cassette as well. Not a cheap replacement. Replace those parts, "give it some beanz" and see what happens. Or, you can replace the bottom bracket (the internal bearings near the crankset) and see if that helps.
Discussion Starter · #3 ·
The chainring is a suntour, and no longer spins true the cassette is a good shimano and I can see no wear on this I can replace the chain, I just need to no if the shimano hollow tech 2 will fit the xt,thanks for your help mate
Shimano hollow tech 2 xt, on my frame sorry my punctuation is a bit shoddy
Well, the crosstrail has a standard BB threading and the suntour crank is most likely a standard mtn bike crankset so I'm assuming that it'll be an easy swap. Of course, you would need to replace the BB too.
Again, if the chainring is toast, the cassette and chain most likely are as well. Take it to shop and have them check your chain for wear. If it's stretched, time for a drivetrain replacement.
old fart
Agreed. As a general rule of thumb, replace the cassette and chainrings at the same time. You should get 2 chains for each cassette if you keep the chain clean and lubed. In other words, get a chain wear gauge, and replace the chain whenever it get to .75% wear. When the 2nd chain is worn, replace the cassette and the high-use chainring.
1 - 6 of 6 Posts
