1 - 20 of 27 Posts
7 kids and bills leaves me lacking the funds to do what I want - but as some of my previous posts have stated - I'm 6ft8 280 lbs and have a new Cdale Trail SL1. Stock wheels Maddux DC3.0 with Shimano hubs
and WTB nine line 2.0 tires..
I know I'll kill this set, the LBS is wanting $600++ to build me a set to handle me...
I realistically can swing $300 - 450 IF I sell my stock set - hoping for $150 for that...
It's a 10 speed Shimano - assuming it's 135mm rear and 9mm qr front - sound right?
I found this set used on the bay - Original Flows -XT hubs
Stan's Flow 29" XT Centerlock Hubs with 160mm XT Rotors and Captains | eBay
Then there's these - VELOCITY BLUNT RED 29IN SHIMANO XT DISC HAND BUILT WHEEL SET READY TO SHIP
I'm open to suggestions but $600 I can't swing - College and braces are calling....
Thanks so much!
Bob
No talent hack
FWIW: As a fellow bigger-clyde, I would NEVER buy a set of used wheels. More trouble than it is worth if you need reliability.
turtles make me hot
I love Flows for a big guy wheel but those look like the old ones. The new ones are Flow EX.
Also maybe look for a wheel utilizing the Shimano M529 hub. It's rated for 36 tooth cassettes and 29" wheels. Better clyde hub IMHO.
Vassago Bandersnatch, Motobecane HAL Comp 27.5+, Specialized Stumpjumper FSR 120 26"
CUSTOM WHEEL BUILDING PROGRAM you pick it we build it PROWHEELBUILDER
$411.
If you want to go to $625, I would swap the rear hub out for a White Industries MI6. Both of these options should be strong enough to keep you on the bike.
Would not recommend the M775 hubs at all...lots of broken axles and freehub bodies. The M756 while not the best choice from Shimano (SLX M529 would be stronger) would be the better choice with cro-mo axles.
I would check with Mike at Lacemine29.com and see if he can lace up a set of M529 hubs on Sun Ringle MTX33 rims...BOMBER and should fit within your budget.
Discussion Starter · #7 ·
I checked with Mike - $900... I'll check with him again
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Found a new set of Halo Freedoms for $375 - I've heard they are up to the task of my weight and riding/bashing style... Trying to get ahold of Mike also - his email on his website isn't accepting my info.. :(
I've been riding the stock wheels on a 2014 Trail SL2, same as yours I believe, for a couple of months now. So far one trip to the LBS to get trued. My trail has a ton of roots and rocks as well as a few 12" or so drop off's and fairly rough downhill sections. I am 325 geared up and have not "crushed them quickly" but I don't try the bigger drops either. That being said I bit the bullet and placed an order with Mike based on his recommendations. King ISO hubs and Pacenti DL31 rims. I'm looking forward to getting them on the bike.
turtles make me hot
OP, Why not just have your wheels tensioned properly and ride em while you save up for an awesome set of wheels?
Most rims will survive some fairly gnarly trail riding if they're built properly.
One of my friends is like 305, bought a new Trek Rumblefish and the wheels were wobbling after the first ride. I took them, loosened them up and retensioned them completely. They're staying nice and he's even riding a little harder as his skills increase.
Discussion Starter · #14 ·
Thanks all for the great advice. I can sell the originals for $200 - would seem the way to go to add some $ and get a stout set from the get go..
I got a nice set of Flow EX's from Merlins across the pond for about $500 with hope hubs. Love them and they are bomb proof. I'm 6' and 270 and ride pretty aggressively on a steel SS hardtail. No issues at all.
Discussion Starter · #16 ·
I have a set of Halo Freedoms coming - they were cheap and from what I'm told nice for the $$ - About $110 after I off my stock wheelset!
Yeah!
I don't mind my current wheels - but my LBS says I will crush them quickly
I think your LBS is only interested in selling you a new wheelset.
From 400 to 350Lbs I rode the crap out of those same wheels on an F5. After it became apparent I would continue to break spokes every few months, I had the shop rebuild the rear wheel with straight gauge spokes. It got better, but spokes continued to break.
Eventually, I realized the shop wasn't doing a good job with the spoke tension. Found a new shop, replaced all the spokes with fatigue cracks, and had both wheels retensioned by a guy that apparently knows what he is doing. No more spoke issues.
My other issue was that I was bending the axle enough to cause rotor singing when I reached for my water bottles. At under 300Lb, I think your axles will be ok, and they are dirt cheap, you just need to get a wheel guy that knows his stuff. If you still want a new wheelset, you can build up a custom stout set by being saavy.
Here's what I just rolled out on this week:
Front Wheel:
Hub: Shimano XTR M988 (32h) - $118
Rim: Mavic EX729 (32h) - $72
Spokes: Wheelsmith SS14 straight guage 2.0 - $9.60
Build Charge: $50
TOTAL: $249.00
Rear Wheel:
Hub: Shinamano Saint M810 (36h) - $80
Rim: Mavic EX729 (36h) - $72
Spokes: Wheelsmith SS14 straight gauge 2.0 - $10.80
Build Charge: $50
TOTAL: $212.80
All said and done: $461.80 for a set of very DH capable wheels.
Now, there were additional charges for me as I was adapting 12 and 15mm hubs to a 9/10mm frame, but that's moot as you can pick whatever hubs you want. My point is that you can have a shop you trust build you a super strong wheelset without a massive cost penalty if you are willing to source your own parts and not go with the latest and greatest for every piece (and the shop doesn't try to rip you on the spokes or build charge). Last year's gear (or the year before that) is perfectly fine and a lot cheaper.
Larry from Ghisallo Wheels - Custom Wheels built mine (Flow w CK SS hub, 36h, DT spokes and Sapim nipples) for around $750 including shipping to Canada couple years ago. It was one of the cheapest prices out there, so I think it would be worth a shot asking him for a price of whatever configuration you want.
Another alternative is to ride the crap out of it for now, start putting little cash on the side every week, and then hit the big sale at the end of the summer. Wiggle Cycle | MTB Wheels + 29" (622) Wheels they have wicked deals at the end of summer, I think a lot of us here got Hope/Flow wheelset for around $300-$400 last year or the year before.
My local shop built me a very strong rear. I don't tend to break the front .
Shimano Durace hub, MTX rim, 36 straight 14 SS spokes. So far, very strong.
The MTX rim is super strong..!
Under $200, with new disk.
PS, I am 6'4", 314#.
Big Test Icycles
I have had Universal Cycle build me several wheel sets. They have a wheel builder link that allows you to mix and match your desired parts. Being a hefty guy a custom build is worth the money. They often have blow our Mavic rims which are basically last years stock. I've pieced together solid builds for under $500. It's well worth your time to take a look
1 - 20 of 27 Posts
