Yup Johnny. Just check your info before you post.
I will restate the MX Comp ETA is a fantastic fork and if you shop around, you may even be able to swing the Pro.
Stating clearly for those reading into it way too much: Turners are designed for heavy duty riding and that's exactly how I ride. I would not trust anything less that what the frame could handle and that's why I have an MX Pro ETA on the front of mine. I regularly do jumps and drops and the fork has not given any trouble, whatsoever. I have been using Marzocchi since 98 and have been very happy.
Here you are suggesting that the seals on your beloved Duke aren't any good. I guess that's you buying into the hype that Rock Sucks seals suck:
http://forums.mtbr.com/showpost.php?p=263966&postcount=4
Here you are stating that the converted Zoke you have is "not bad":
http://forums.mtbr.com/showpost.php?p=164082&postcount=4
Here's another interesting thread about Marz with some more posts from you and I:
http://forums.mtbr.com/showthread.php?t=22528
Here you state the MXC is stiff, yet not as stiff as the Duke. You stated the MX Comp is noodly. Which one is it?
http://forums.mtbr.com/showthread.php?p=156627#post156627
I would suggest that if you don't like Marzocchi so much, don't ride them. You have the bottom end fork, with different construction from the better models and you are offering advice when you don't know anything about the upper models.
