1 - 11 of 11 Posts
uh, or something!
any ideas short of changing the rear hub. what's the most clean way - would like to avoid using a singulator type tensioner. suggestions please...thanks.
The Duuude, man...
I didn't check those links, but the hottest setup going is an eccentric Bottom Bracket....
Not an eccentric BB shell - your frame doens't have one...but the BB itself...is eccentric...and will go into any geared/standard frame.
there was a thread on this site of a new company putting out a very high quality unit just a couple weeks ago. I'm too lazy to go find it, but its right on here...perhaps linked above
bigwheelboy_490 said:
I'd go with a White Industries Eno Eccentric rear hub. Nice and clean.
The only disadavatage is that you'd have to factor in the cost of the eccentric caliper mount too, and maybe a new caliper as I believe it has to be post mount, not IS.
I'd still go for an eccentric BB conversion - looks just as clean and would end up cheaper too.
1 - 11 of 11 Posts
