I currently use a mr16 20w halogen light with a 12v 6500ah li-ion battery & was looking to build my own light for both brightness & longer run time.
I have been lurking and researching on this site for several days & kind of have an idea of what I want. I have access to a metal working shop so they fabrication & mounting should not be a problem. I have a few questions about the electronics though.
I was looking at using one of Cutter's 3 or 4 led xp-g pcb's. I will research the optics later. (Any suggestions for a nice tight beam
I will probably use a buckpuck 1000mah or
b2flex for a regulator. Could I power 4 led's at 12v at 1500mah with this. Or would a 3 led system be better? I want the brightest system possible. This will be mouned on the handlebars of a Jamis Durango 2.0
