The spacers are needed for the crank to fit correctly.
sorry, correction, 68mmBB housing.View attachment 2027482
View attachment 2027481 So, went from the junk on the floor, to the Box stuff. I put the BB spacers where they are at the recommendation of an article (63 mm BB housing). Everything works as it should but the chain line seems a bit wonky and chatters a bit. I’m going to take one spacer out on the drive side and move it to the NDS. My question is, if needed can I put all three spacers on the NDS?
This exact trouble came my way yesterday assembling a beater/rain bike. It is not great stacking all three spacers on the non drive side because the left side BB often has fewer threads. It is optimal in a 72mm BB or the exo BB bearing is left barely hanging on. These dedicated 1x cranks have limited chain line adjustment. I end up looking for 3x cranks to use the middle position with a bash ring outer. And a spider allows for chain ring spacers. 2x to 1x crank is even worse than 1x only. I want to bias to the big cog that gets the most torque and time spent cranking than high gear, what you are seeing. A short chainstay makes it even harder to get right because of the more acute angles. For your crank, does it support an offset chainring?View attachment 2027482
Glad you worked it out. Here is my solution. For the rain bike I tried a Samox crank, but it was designed for 73mm BB. I needed three spacers, 6mm, all on the left side which left the shell hanging by a thread so to speak. The Samox has a one use steel ring that can't be spaced and I bias chain line to first gear.Ok, figured out a crankset that’ll work, Shimano Zee FC-M640 (50 mm chain line). So will return the Deore and install the Zee.
Thanks for the input and help!
