Hi
I've got a 38/26 on the front of my hardtail with a bottom pull older XT mech.
Due to the lower size of the chainring from a std big ring, I cannot lower the mech on the frame enough to get close to the std, say, 2mm gap btw mech cage and ring you would use on a normal set-up.
The mech cage is set just a business card's thickness off the chainstay!
I have about a 10mm gap above the 38t to the mech cage.
I hate dropping my chain. The mech is adjusted just right but I think I need to close the gap. As I see it my options are to
1. Live with it.
2. Road front mech. Do these have less drop on the cage?
3. Saw the bottom off my mech and lower it to the correct position.
4. Won't be fitting a bash guard type affair as I'd rather put the big ring back on.
If I saw the base of the mech cage will it give me probs if I switch back to 3x9? Flexing issue on shifts?
Thanks for you help dudes.
Davo
1. Live with it.
Davo
