Helius CC - Bearing Caps on Rocker Arms
640 Views 2 Replies 2 Participants Last post by  steve_b77
Having a good look round my frame today and after noticing the rear felt a little flexy I decided to re grease the bearings on the rocker arm.
When I took the lower one out the bearing cap doesn't sit flush to the rocker, there's about 0.5mm (if that) between the cap and the face of the rocker.
I take it this isn't normal as looking at all the others they sit flush to the rocker/frame etc.
As a temporary fix, until I can order new ones would a thim washer placed between the bearing cap and the rocker be ok?
1 - 3 of 3 Posts
I'd email Simon @ Nicolai UK to be 100% sure.
I did just that, sorted the problem with a thin nylon washer for now - just to take up the slack.
Problem solved:thumbsup:
1 - 3 of 3 Posts
