I got the Burner built up today and took it for a short ride. Thanks for the advice everyone...
Spec:
Medium Burner frame
Chris King ISO to DT 4.1d w/Comp spokes and Salsa skewers
King headset
Thomson post/stem
Easton Monkeylite riser
Titec saddle
Race Face Turbine LP
XT drivetrain
Avid S7 levers w/discs
Fox Vanilla dropped to 100mm
Crank Bros. Candy SL pedals
Kenda BG/Nevegal 2.35
First of all, the bike looks pretty cool, the frame quality is about the same as the SC, maybe a little bit better. The color is a cobalt/electric blue and it perfectly matches the Chris King blue on the hubs.
As far as the ride is concerned, there is no contest -- the Burner is in another league compared to the Heckler. I didn't realize how stiff the Heckler was until I rode this frame. All the little stutters and roots which the Heckler barely filtered were completely muted. In comparison, the Burner is a much smoother, stable ride -- the difference is really quite noticeable.
BTW - I set up the Heckler as suggested by Santa Cruz as well as experimenting myself -- I never came close to find the sweet spot that I now have in this frame. I've come to the conclusion that suspension of the Heckler is really intended solely for moderate to big hits, which it did feel plush and indestructible. The Burner, as of yet, doesn't have that kind of confidence inspiring ride, but it does handle roots and other trail nuisances much better.
As would be expected, the Burner also pedals much better than the Heckler -- I am one gear faster. This is despite the fact that the Burner came out to 29 pounds (which I found surprising, considering the relatively light parts I used). I haven't ridden it enough to gauge the handling, but from what I felt -- it was very promising.
So, basically, FOR ME, this bike kicks the Heckler's ass. The only way to make it perfect would be to preserve the light, snappy feel but add a extra travel in the back - I'm a little paranoid about bottoming it out and ruining the frame.
BTW, I am 175lbs and I am running 140psi/80psi(spv) -- any other suggestions?
Spec:
Medium Burner frame
King headset
Thomson post/stem
Titec saddle
XT drivetrain
