e-rider said:
hi all,
been looking to trade my ht in for a fs lately and have been looking at the Heckler. After reading this forum I have a few questions regarding setup. How does the swinger coil or air compare to the 5th coil? I am a complete newbie at this shock thing so anything to shed light on this will be much appreciated.
There were mentions of "brake jack"? So will it be necessary to fit a floater to it or will it all be in my head? Thanks.
Oo
I've been on a Heckler with a 5th coil for about 1-1/2 years. At the time the 5th coil was probably the best option, but now I'm not so sure. It works great IF you are willing to spend a great deal of time fiddling with the 7 different variables (1-spring weight, 2-preload, 3-chamber volume, 4-chamber pressure, 5-rebound, 6-begining stoke compression, 7-end stroke compression). The issue I have with any spring shock with a platform is that if you don't want a super plush and active shock, why bother with a spring? Anyway, it is not something that is going make me go out and buy another shock, but if I could do it all over again I would at least look at the options out there. The Swinger 4 way air and the Fox RP3 sound like good options, though they have a shorter stroke, giving you 5" of rear travel as opposed to 5.6" with the 5th coil or Fox DHX.
As far as brake jack: yes it does exist, and I can tell a difference in behavior between this bike and a true horst-link, but it has never been something that makes any real difference in my book. It's just part of how the bike behaves, and I've adjusted my braking style accordingly. I think brake jack is more of an issue when someone has really bad form, and relies mostly on the back brake in scetchy situations. This may be unavoidable in DH racing, but not for the riding that one is likely to be doing on a Heckler.
Kapusta
