This is a suspension question about a Santa Cruz Heckler...
I have a Push Industries 2005 Fox Vanilla RC that was DH valved for a Kona Stinky (2001). The shock has a 2" stroke and a 7.875 eye to eye with a 600lb spring.
I am asking this question since I don't know much about suspension.
The Heckler uses a 7.875 eye to eye shock, but uses both a 2" stroke and a 2.25" stroke. When I asked my shop about using the Push shock that I have they said something about the leverage ratio being off, I really don't know what that means.
Could you tell me if the Push shock that I have will work on the heckler (2006)? And if so what weight spring should I use, I weigh about 195lbs.
And if you have time could you compare the characteristics between using the Push shock on my heckler compared to the shock I am currently running, a Fox Float R with the lowest pro-pedal valving (7.875 X 2.25).
My use for the bike is mainly XC, but I also do ride slalom, DH and occasionally go dirt jumping.
