1 - 9 of 9 Posts
I'm looking to set up a Heckler as a trail bike. Mostly simple single track in the midwest, but I want it to be capable of riding tougher trails as well. I'm a big guy, about 250 or so and I'm thinking of going with the DHX 5.0 Coil instead of one of the air shocks. Is this a good choice? I don't want the extra weight if I don't need it, but I do like the simplicity of the coil shock. I had a Float fork go out on me once and I swapped to a Vanilla R which I love because it just works all the time. I just want to make sure the DHX 5.0 Coil isn't going to be overkill for what I'm doing with it.
DHX 5.0 coil is the perfect choice, go for it! (from a 240lbs Heckler rider with DHX 5.0 coil). Your next question will be what spring weight, now that is a can of worms, I'll start you off by saying 600lbs ish depending on the riding you're doing.
DHX-5 coil super plush I'm 210+ in my gear 450lb spring which is slightly too hard, could do with a 400lb ok most of the time until you hit a rocky climb , when it doesn't track the ground as well as it should,
07 Heckler Large. I had atest ride with the air rp23 set up the sag but it still bottomed out on a harsh trail.
Cheers
Discussion Starter · #5 ·
Thanks for the info, sounds like the DHX Coil will be the right choice.
It's the new style Heckler so I'm thinking either a 500# or 550# spring. It will come with a 400# spring because that is the biggest that SC says they stock, so I'll have to get the other directly from Fox. Anybody know off hand what a spring from Fox goes for?
Had a 5th coil (reworked) and switched to DHX 5. I'm loving the new shock.
240lbs on a 650 spring
Go to Cambria
http://www.cambriabike.com/shopexd.asp?id=53816&page=FOX+RACING+SHOX+DHX+5.0+SHOCK+'06
Somehow they have a bunch of '06' DHX 5 shocks ($260) as well as some '07' Vanilla RC2 forks ($670.00) for sale.
1 - 9 of 9 Posts
