As with any TFT Tuned Rebuild Service, your fork is completely disassembled, cleaned, inspected and bushings are sized to the mating inner fork tubes to maximize the chassis performance.
Then we add the PUSH Factory Fork System which is for those riders looking for the ultimate tailored performance out of their fork. Our technicians, taking into consideration rider weight, style and frame application, utilize the PUSH exclusive FDV Rebound Piston upgrade system to increase traction, bump sensitivity, and big hit control.
Our technicians then install Fork Seals, Fork Wipers, Crush Washers, O-ring kit, and finish your fork off with RSP Racing Fork Fluid. Lastly, a careful application of new Push “Factory Rebuild” decals.
I had my 454 Pike coil u turn Push'd , you basicall give them your weight, type and style of riding and they set the fork up for you, I find now the faster I go the better things get, where before it used to get worse depending on the trail, I have certain trails that I used to have to back off on now I can just ride straight through seems as if the bike tracks better and is under more control than before, makes the Heckler even better, I have the Push'd DHX-5 coil also set up for my weight etc...again this upgrade makes thee Heckler track better I think the wheels are following the contour of the trail more giving more grip and control, I presume the Air Pike will have similar attributes.
