Heat sinks and hardening-
Actually 4130 with TIG welding in particular creates a hysteresis curve-
sort of like a goofy sin wave with the highest value (amplitude) just behind the toe of the weld. This is well documented for many steels.
So you end up with 4 zones- stay with me on this and try to visualize from right to left in the diagram:
- Harder than delivered zone (usually about 4-7mm) from the weld toe centerpoint outward
- Crosses the zero axis (the original delivered strength)
- Softer than delivered zone- after crossing the zero, 4130 goes to a lower value that is dependent on how much time and heat were applied, followed by how quick did the tube cool.
-Return to delivered (before welded value) the bottom of the curve usually returns at a slower rate than the high value (more distance to get beck to the delivered value.
So why is this important? a heat sink will slow down the cooling process so that you have less of a contraction or distortion problem. This really makes a difference in AL7005 where the expansion/contraction is 3x's what steel is.
If someone is fast and uses the minimal heat, they end up with less change in the strength values of the tubes and less distortion. If you use more heat and are slower, well, you get the other result.:skep:
