Headset with a thick lower stack height?
1482 Views 6 Replies 5 Participants Last post by  Speedub.Nate
I've a 16" on-one inbred ti and my canecreek 110 headset has such a thin lower stack height, the adjuster knobs of my fox will hit the downtube should I get into a crash. I find the canecreek S3+5 to be abit too thick for my needs.
I'll rather try to avoid dirtjump or downhill headsets for the weight, so I'm wondering if you guys have any headset with a thick lower stack height to recommend? Something around 15-16mm would suffice. Thanks.
1 - 7 of 7 Posts
You can get a chris king headset with a taller baseplate that might give you the clearance that you need. the base plate is here: http://chrisking.com/parts/baseplates
The plus 5 is 17.3 is it really that big a difference?
Yeah, what's so objectional to the CC +5?
CB=10mm /65.5g
CC S3=12.3mm /112g
CC S3+5=17.3mm
FSA Orbit UF=14.5mm /113.5g
Actually, it's boils down to vanity. Somehow the S3+5 headset looks wrong to me.
Erm, Crank Brother headsets have even lower stack heights, wouldn't it?
Yep, the Crank Brothers directsets are about the lowest stack height you can find in a conventional headset. Those are lower stack height numbers I referenced in my previous post.
If you're worried about appearance... well, don't be. I swear, you're looking at it now as this big ugly thing, but you'll never notice it again when you're looking at the bike as a whole.
And stack height is stack height -- it's not as if Cane Creek's 17mm of black anodized aluminum is any uglier than FSA's 15mm of black anodized aluminum. Both are prettier than a dink in your downtube.
1 - 7 of 7 Posts
