Hey guys-
Couple headset questions hoping to be answered!
1) What happens if you over tighten the headset (stem bolt)? I tried over tightening it and it got a little tighter but it never got so tight that the handlebars didn't turn or things wouldn't rotate. Normal?
2) What's the consensus for how much steerer tube should be in the stem? I hear 5mm below the top of the stem or at least so the top of the steerer is level or higher than the top stem bolt. Mine meets the latter requirement and is level but is more than 5mm. Anyways, my LBS said it was fine as is but just seeing what others say
3) Was wondering what the proper orientation of this washer is in the stack. There is a little groove or channel on one side of the washer (shown in pic attached). Does this groove face down or up when being installed in the headset over the open bearings?
