1 - 6 of 6 Posts
Hi All
As a pandemic goal, I wanted to build a bike from the frame up and learn how to tune it. I've almost got it all completed but am stuck at figuring out the right headset.
The frame is a classic 1998 Giant ATX 890. internal dimensions of the head tube is greater than 40 mm. I picked up an Orbit IS headset but it looks to be the wrong one. Below is a pick of the head tube.
Headset Pic
Am I missing something? Head tube cups? ES vs IS?
Okay, that looks much closer to 44MM on the ID, a digital caliper will be more accurate on the measurement but lets assume it is at this point. I'm also going to assume the steerer tube is straight 1 1/8". Then, according to the links provided it is the one in the first example in the BIG BOLD BLUE letters, Upper Stack ZS44/28.6 with Lower Stack ZS44/30. The Tree Fort bike site also lists the replacement for the original to be the same so this does seem to confirm the correct type and size. See attached links.
Let us know if you need a recommendation on installation.
1 - 6 of 6 Posts
