1 - 4 of 4 Posts
What size rotor are you using? If you have a big 7 or 8 inch rotor then try downsizing to the 6in rotor!
Do you have the Stroker Ryde’s or the Trail’s, the Ryde’s are pretty poor brakes and nothing compared to the Trail’s, especially when it comes to modulation. The grab on the Ryde’s will feel pretty vicious, dangerously vicious as some people have said…
Discussion Starter · #3 ·
They are the Trail model. I'm using a 7 inch rotor. I'll reduce it to 6 inch, which won't reduce my stopping much. Thanks.
Do you have the Stroker Ryde's or the Trail's, the Ryde's are pretty poor brakes and nothing compared to the Trail's, especially when it comes to modulation. The grab on the Ryde's will feel pretty vicious, dangerously vicious as some people have said…
...idios...
Have you tried different adjustments to the throw of the lever? The position of the lever blade relative to the bar can make a considerable difference to the feel of the brake and is often overlooked when setting brakes up.
1 - 4 of 4 Posts
