My inside piston on my front brake (HFX 9) keeps pumping out. The outside piston retracts just fine. I followed the instructions in the manual regarding pumped out pistons: removed pads, pushed piston back in with a box wrench, put pads back in, reinstalled caliper, centered it on rotor, and squeezed the lever. Both pads squeeze toward the rotor, but the inside one barely retracts and stays in contact with the rotor. How can I correct this problem? Or, does this sound like a faulty brake, I should send back in under warranty?
Thanks to all those who responded to my previous posts. By the way, I finally found out what was causing the squeak...it wasn't the brakes or rotor, it was my hub. I have a lefty and the self-retracting bolt in the hub was the culprit.
