There's a 2.5mm allen at the knuckle of the lever (near the master cylinder). That's the reach adjustment. Over time, they tend to back themselves off. Play with that, see if it helps.
You can order through your LBS but your best bet is to order the HFX-Mg master, nuch better.mtbike_AK said:Where can I find parts for hayes FX9 disc brake? My rear break lever/master cylinder is leaking through the little plastic stopper each time I pull the brake?
no need to replace the whole master cylinder... yet! Or, perhaps the leak is due to fluid expansion. If so, rotate master cylinder to upright position, insert bleeder tube, remove rear wheel and push pads back to their fully retracted position, remove bleeder tube and replace plug. Good luck.mtbike_AK said:Where can I find parts for hayes FX9 disc brake? My rear break lever/master cylinder is leaking through the little plastic stopper each time I pull the brake?
