A 2mm allen adjusts the reach. The reach adjuster is by the "knuckle" under the lever blade.
You can remove the wheel, and pump out the pistons a little bit. While you're at it, make sure that your pads aren't too worn.
There's a chance that your brakes may just need to be bled.
