The first time I tried to bleed my Strokers with that crappy standard Hayes bleed kit, I discovered rather quickly that the bottle/hose would pop off the bleed nipple :madman: and DOT would fling out the hose in a lovely arch as it fell. Having a bike rolling around too is bad news when trying to do this sort of thing 'one person' so used this as my last straw and went and bought a Park repair stand (best tool I ever bought for a bike.)
I didn't have a compression bushing, but found a plastic washer that fit, and duct taped a re-usable zip tie to the bottle, to hang it from the tire that I had prevented from rotating with another tie. I put another zip tie on the bottle on the lever for a 'look Ma, no hands' setup; with the bike on my Park repair stand.
NOW I was ready to bleed it. Slowly squeezed the bottle at the caliper end, while rotating caliper as per Hayes video. Did this a few times, watching for leaks from either end, and rags/alcohol at the ready. Finally get clear fluid- my previous fiasco had allowed much air in- another squeeze, and closed both ends. Wiped down both ends with alcohol, re-aligned brakes with feeler gauge (second best tool I have ever bought for my bike) and I am done. Not one drip of DOT.
With a few simple mods, that crappy Hayes kit can be made into a real bleed kit. The bottles I use are .99cent store picnic mustard bottles, and I also found some more hose there. You can find bushings at home-improvement stores/hardware or possibly automotive. Yes the stupid little compression bushing should come in the Hayes kit-even the basic kit IMO. But I was able to put together a nice bleed kit after stepping back and identifying all the problems and making cheap solutions (except for Park stand, which was not specific for bleed kit only, get bike held solid somehow.)
Next time your brakes need bleeding, you will either take it to the shop, or you will have to do it yourself. If you decide to do it yourself, you will have to get/make a bleed kit that works without having to fight it or it will be rather unpleasant experience, Dot or mineral oil. Maybe it's less of an issue if it's mineral oil flinging out the hose, but frankly I would rather be bleeding the brakes and not painting the walls with mineral oil.
