jtmartino said:
Hey Mimi,
Those aerosol cans used to clean electronics work well for cooling stuff down. Hold the can upside-down when you spray it, and the liquid CO2 will come out and be plenty cold. Also, the plastic straw makes it easy to get into tight places.
Hey King! Thanks, I did tried that I have a compressed air in the can I dumped quite a bit on the head tube I moved it a little.
Updated, I finally got it out:thumbsup: Actually I took it to my shop this morning my Mech had a hard time with it too. He used a mini sledge hammer to pound it out. After he got the bottom one out he flipped the frame and started working on the top cup. I asked if I can give it a whack. It took 3-4 times more effort than the normal one for sure. Now I know.
What I learn from this? Cooling method is a bit easier well faster than hot( steaming) a couple of burst seems to do the job. Bigger heavier hammer made the job easier. It's way harder to get it out than one would think even when the cup is already start moving same force still require to get the cup out.
Thanks all for helping.:thumbsup:
