Hello fellow riders. In this thread we will discuss any mods that some of us have made to bike components. I am not talking about changing stuff onto your bike, like new fork or new shock, but rather what mods have been done to your existing gear. I'll start first with my very short list
1. Shimano zee calipers, changed the cotter pin to threaded screw like the saints.
2. Shimano zee levers, changed only the lever blades to m8000 blades. Body remained zee.
3.Removed the snake eye screw from bite point abjust to headless allen screw in black.
4. Converted my frame from quick release to thru axle making a derailleur hanger insert nut in a lathe from 7075 aluminum and stainless steel. (made 3 in aluminum 4 in stainless steel.)
5. Made a custom thru axle from solid piece of 7075 aluminum rod.
6. I increased the stroke to my rear shock (xfusion o2 pro rlx) by removing the spacer inside it.
7.i installed a cable canal underneath the downtube, and i removed the cables from inside the frame and passed them through the cable canal. That way i can remove them anytime i want just like canyon bikes. The cable canal also protects the frame.
8. I filled a lilttle bit of plastic from the chain tensioner so i can tilt it more degrees. It literally had no tilting adjustment only distance.
Please share your mods or what you have imagined that could be done.
admin edit: add photo
