I'm wondering if this is a common problem place for Fuels to break.
(excuse mud)
deanopatoni
(excuse mud)
deanopatoni
i've never seen that kind of beak on a fuel before, i had an slr front triangle fuel and it cracked at the weld between the top and seat tubes and had it replaced under warranty and some cash for a carbon front.....i've also had the slr alu rear triangle crack at the chainstays to which i had it replaced under warranty and some cash for a carbon version,i've since had no similar problems.deanopatoni said:I'm wondering if this is a common problem place for Fuels to break.
(excuse mud)
deanopatoni
I agree marco, Treks warranty is great. My original SLR Fuel90 front triangle broke in the exact same place as yours. They replaced it with a Fuel95 front (the one in the photo) in the UK even though i'd bought the bike in New Zealand!marco said:i've never seen that kind of beak on a fuel before, i had an slr front triangle fuel and it cracked at the weld between the top and seat tubes and had it replaced under warranty and some cash for a carbon front.....i've also had the slr alu rear triangle crack at the chainstays to which i had it replaced under warranty and some cash for a carbon version,i've since had no similar problems.
i love the fuel and i love TREK and their warranty systems....i'm a trek man for life!![]()
Thanks for the frame size info. I have not broken mine, and I don't plan on it, it's a MED.Fuel_95 said:Size is a 19.5" frame BTW.
Yip, when the frame broke I was just cruzing along single track, went over a 1ft sort of drop off and then I noticed that I could not change into granny ring. Stopped, got off the bike and tryed pulling the derailier cable manualy to check that the mechianism was getting full movement, it was so I got back on. Rode along a bit, trying the front shifter again, but it still would not change down to the granny. I stopped to get off and as I did the frame gave way under me. My instant thought was 'wow, my seatpost has just bent'. But then realised it was a bit more serious than that (as the photo illustrates). It must of been a hairline fracture that was just waiting to break. I was very lucky that at the time I was not hooting down a hill.damion said:Why the failure at the cable boss?
Is this a result of a crash?
Have you been carrying the bike on a car for lots of miles?
That is an odd spot for a failure....What did trek say?
Edit: I see it now. The failure was at the junction of the seat tube and the support gussets for the rocker pivot. That I have seen before, and I am sure that Trek will take care of you, as long as you are the original owner.
Do not be shocked if they offer a EX frame or a Liquid frame instead. They may want you on a heavier frame, that is stronger.
Final Update....deanopatoni said:I'm wondering if this is a common problem place for Fuels to break.
(excuse mud)
deanopatoni
Good point. I just checked, it will be Alpha Aluminium. I went through my LBS with my original receipt.LiquidX9 said:The SLR frame has been discontinued for a few years now in the US. Are they still available in the UK? I own a MED 2002 SLR and haven't had any problems. But I don't do anything real crazy on it. THats what i got my 2005 Liquid for. Did you go through a Trek dealer or did you just call up Trek? I bought both of my Treks used so I could have a problem with Trek honoring a warranty. I'd probably have to go through the LBS that installed my Chris King headset. I'm pretty sure the mechanic there told me if I had any problems to go through them.
That's good to hear. It's always good to know that a company stands behind their products.deanopatoni said:Final Update....
Trek have kindly agreed to replace my entire frame (with a SLR model), instead of just the ZR9000 front triangle. This is because there are no longer any ZR9000 frames in the standard Fuel range. They will be charging me a small fee (£60) but this is still a great deal as this is the same price as a bushing kit (which I realy need after 5 years use).
Conclusion.
Trek rocks!!! No fuss, honest, frame warranty.
Me out.....
deanopatoni
