Don't know about Stans formula but Slime has a new Pro Tubeless that is ammonia free.
I'm pretty sure it's not ammonia-free, but I do think it has less than Stan's.mtnbiker72 said:Don't know about Stans formula but Slime has a new Pro Tubeless that is ammonia free.
Taken from http://www.slime.com/faq.htmlmtnbiker72 said:
Perhaps because it's such a small amount, they are not required to list it on the MSDS???Does it contain ammonia?
Yes it does contain trace amounts of ammonia. Slime Pro Tubeless Sealant contains much less ammonia than competing brands.
Why does it seem less "chunky"?Mike B. said:Our formula hasn't changed for several years. Same ingredients, same ratios, etc for at least 5 years.
Pinch flats can be more difficult to seal if the threads of the casing are actually cut in any way. That said without seeing your friends tire I can't begin to speculate as to why it didn't seal. We'd love to have everything puncture taken care of but unfortunately that's just not possible right now.
That could very well bebholwell said:Taken from http://www.slime.com/faq.html
I've heard this from several people I ride with in addition to on these forums. Instead of throwing out the remaining bottle, I wonder if mixing in some Slime For Tubeless (the stuff with black chunks of rubber in it) might help out a bit.twowheelsdown2002 said:Why does it seem less "chunky"?
I used to shake it up, then hold my finger over the end and invert it, and let it settle for 10 seconds before dumping it. It would barely come out of the bottle because of all the chunky stuff. I had to cut the tip very large for it to come out, and sometimes it would clog up.
Now it just dumps right out, and I don't feel any chunks as I release my finger off the end. Sure seems different to me.
As mentioned in the other thread on this, UST does not need a latex based sealant so if your simply looking for flat preventative...go with Slime for Tubeless Tires (not the same as Slime Pro Tubeless...which is a sealant). It wont dry out and it is quite effective.Gotta Know said:I tend to eat slime when I'm bored.
But seriously, which is better when using UST?
What's best for tubeless ready like TNT?mtnbiker72 said:As mentioned in the other thread on this, UST does not need a latex based sealant so if your simply looking for flat preventative...go with Slime for Tubeless Tires (not the same as Slime Pro Tubeless...which is a sealant). It wont dry out and it is quite effective.
Of the Slime products, use Slime Pro for tubeless ready tiresdulyebr said:What's best for tubeless ready like TNT?
