1 - 11 of 11 Posts
Dozer
During my ride last night, I had a flat tire. After fixing it, I rode about a mile or so but noticed the rear end of my MotoLite felt a little squirmy. At the next stop, my riding buddy noticed that the linkage bolt that connects the chain stay to the seat stay had worked itself almost entirely out!
Has this happened to anyone else? What on earth would cause it to work itself out? Would putting blue Loctite on the threads impede performance at all?
I had this happen to my 09 FTM. I put loctite on it and made sure I did not get any on the bushing in the frame. Put it in the threads of the female nut, not on the threads of the male allen screw. I also put a little waterproof grease on the out side of the allen nut to keep things moving smooth. I'm not sure if this is OK for the bushing or not but I have not had any problems. just wipe down the pivot real good so the dirt wont stick to any grease that may have squeezed out.
Happend to mine once and a while. I suggest finding the torque specs on that bolt when you take it out for the loc-tite.
Yup, make sure you use some loctite and torque it to the proper specs.
Dozer
Discussion Starter · #5 ·
Thanks guys. A little bit of preventative maintenance now is a lot better (and cheaper) than having the swingarm fall apart, break, and possibly wreck me.
Anyone have a good line on replacement bolts? The head on one of mine is stripped.
Unfortunately the bolts and bushings are different for the FTM and Motolite. We do recommend using blue loctite on the threads to make sure the Horst Link bolts don't come loose.
Titus_Mikey.....help us Brothers Out
Can you hook us up....
I've had the same problem two weeks ago but was able to make due with a bolt from the hardware store.
Dozer
Discussion Starter · #9 ·
Talk to BikerBob. He's sending me out some bolts pronto. :D
At Work
Check them periodically, found a loose bolt a few weeks ago.
1 - 11 of 11 Posts
