1 - 20 of 31 Posts
If not, it would be cool if those of you running your bikes with a suspension corrected 26er fork or a custom designed non-suspension corrected rigid 29er fork could throw up a photo of your bikes.
I'd like to see how they impact geometry - especially on smaller sized frames, and even moreso on a small Karate Monkey -if anyone has gone that route on their Monkey.
Thanks.
Mark
Premium Member
MMcG said:
...I'd like to see how they impact geometry - ... and even moreso on a small Karate Monkey -if anyone has gone that route on their Monkey.
Thanks.
Mark
A 26" fork on a KM would totally screw up the geometry. Steeper angles, lower BB.
Recovering couch patato
Unless you get a shim to put on the fork to take up the difference. Steerer won't be made for it though. And the KM is a good 29" frame on which good forks fit, why bother?
Maybe on S sized 29"er it could make sense, but only when reach is on the short side for the rider. Shorter forks also increase reach, you know... a 30mm shorter fork (26" vs 29", give or take) will increase reach more than a full 2" bike size would.
Discussion Starter · #6 ·
Okay Shiggy - I gotcha.
So would a taller Niner fork actually help raise the bb a bit on my Karate Monkey?
If Surly ever makes a change to the frame, they should definitely raise the bb up a bit.
dirty hippy mountainbiker
coconino
This Coconino has a planet X rigid sus corrected 26er fork, although last I saw this bike it had a new custom Vultutre fork cause he didn't like the tight clearance. The bike was built for it though...
-M
giddy up!
-M
Forget about the fork...tell us more about the bike and the seemingly custom rear rack.
B
Oh, so the thing about that rack is that I think it's custom. It's unpainted and brazed steel tubing. It's prety light. It mounts to a cool seat collar that has bolt threads for it. Pretty cool. I think Steve Garo made it too.
On a side note: those are comfy bikes. I've ridden the one pictured and another 26er. Stout, but comfy. Filets are cool looking too.
-M
3327333
Thanks.
Mark
As requested.
Pace 26" corrected rigid fork (440mm) on a custom Kent Eriksen 29'er frame. Emphasis on custom of course because the frame geometry was built knowing that I would have that fork. Plenty of clearance!
And this is the guy that inspired me to use the 26" Pace;
http://forums.mtbr.com/showthread.php?t=177642&highlight=phil+wood+frame
Ed E
3327333
Drewdane said:
Why do that? It's a sincere question, not a snide one.
In my case I wanted the Pace fork. They make two that I could use; a corrected 26" (440mm) and a corrected 29" (465mm). I did not want my bike suspension corrected. The clearance with the corrected 29'er Pace fork would have looked out of proportion and it's not a look I wanted. The 440mm fork works perfectly if you are going non-corrected on a 29'er.
Ed E
Ed E
Copy that exactly!
[offtopic]Ed, did you start a thread on your bike? looks gorgeous!
Looks like you've been trying different setups (the bars). What did you prefer and how are you riding it now??
[/offtopic]
JJ
1 - 20 of 31 Posts
