Ever since I got my bike last year, I have had problems with the front brake rubbing. I had the wheels trued and at the time the guy at the bike shop said not to worry about it and that it might go away after some time. Being that I only had it for a little while, I figured he was right, but it never went away. There is a constant rubbing, sometimes it is light other times it is quite heavy. In a recent issue of Mountain Bike Action, they had a special on fixing brake rubbing. I tried almost every little fix they had to no avail. In the article they stated that chipped paint, dirt, or dents in the dropout could off set the balance of the wheel and the brake would then rub. I checked the dropout, and it is pretty bad looking. The paint is scraped and chipped off, it looks like the dropout is dented slightly also.
I have only taken the front wheel off a couple times, and each time I made sure the wheel was seated properly, so I'm pretty sure I didn't cause the damage. Should I contact Haro about this problem? Is there a warranty issue for this type of thing?
