The MX LO is coil sprung with air assisted preload. If you are above or below average weight, you might need to order a firmer or a lighter spring rate. If you are about average, you can use the preload adjust to set the sag. The knob on the top right side has a little black plug...pop that out and adjust the air pressure as needed.
