Hardware question
472 Views 5 Replies 2 Participants Last post by  Garradmiller
Have a trunnion rockshox select on a marin mount vision 8.
Inside of the upper mount there are washers and o rings. Took the bolts out and didn't see the order of the parts before they fell put. Which go closer to the shock body washers or or o rings?
1 - 6 of 6 Posts
Usually the o-rings, they fit inside of the washers on most shock hardware sets.
You can usually spot a small channel where the o-ring goes on the underside of the washer.
  • Like
Reactions: 1
  • Like
Reactions: 1
Yes upper mount on that setup. Isnt any channel on the washers or on the bushings (non shock side). The o rings are larger than the raised portion of the shock hole. The washers fit nicely against the bushings which would put the orings on the shock. Both ways seem like they could work but both are difficult to keep in place while mounting.
I'm not sure then, you may have to contact Marin...they don't have any exploded view diagrams on their web site that would show how the pieces go together there.
  • Like
Reactions: 1
Yeah i emailed them asking for one. Not much technical info. Thanks for the help
1 - 6 of 6 Posts
