coolmoed said:
I raised my seat on my hard tail(17.5 trek - and i'm 5.10")because it feels alot more comfortable like that(my knees are still slightly bent so it's all good). But when riding trails my weight doesn't feel right. Meaning, when riding trails with alot of rocks if my front tire hits a side of a rock it it makes my bike feel like it want to wash out(flip sideways...like if a quarter is rolling and falls sideways). This feeling is decreased and I have more control over the bike(in this manner) if the seat is lower, but then I have to peddle harder and is less comfortable. Any suggestions?
FWIW. ( I have just posted and discussed about how I bent my saddle rails. <G> However, I watch my riding style always with interest, and listen to others' tales. )
Raising saddle height is a great way to get better pedalling power, but as you are finding, offroad it has a price.
I reckon there are various things involved. You have altered the whole dynamic of the bike/rider unit.
How much did you raise the saddle? If it was significant (1" or more) then you will take some time to get used to it. This is not to say you just have to take it, but factor that in.
When you hit rocks are you off the saddle or on it? It helps a lot if you get up off the saddle a bit, for better comfort (for a start) and also to allow faster movement and responsiveness of the bike.
Is this uphill, downhill, on turns or just generally?
Generally: The simpler stuff.
Firstly, you are putting more weight on the front wheel by raising the saddle height. This could cause what you are talking about, although it will tend to actually give better traction on gravel etc. It can cause the wheel to fall harder off a larger object, where it may have bounced over, or not fallen as hard, with your body lower down. The front wheel has suddenly been given more control of the bike and rider.
Secondly, you are putting more weight on your arms as well, so you will feel the bump more.
Thirdly, because you're sitting more forward and down, you will feel more insecure about the front wheel. Have you tried riding exactly the same places with the lower saddle and seeing if your wheel does actually behave the same way (jumps the same distance) although it feels better?
I would try raising the bars a little, to see if that makes you feel more secure. It will also help to restore the balance you are used to on the bike. Do all of this bits (1/4" - 1/2") at a time and remember where you had it before. Every change you make will cause other differences and problems. If you can, do it in a controlled area with obstacles, rather than simply on a track.
Also try to get back a little when you are going to hit a rock. Downhill or flat that is. Do it uphill and the results can be interesting <G>.
Nick
