I'm kinda new at this... The last time I bought a bike that was more than a BMX bike, I was in 6th grade (1992)
I'm looking at the 'less than $700' Specialized bikes.
Rockhopper Disc
Hardrock Pro Disc
I was told that with my weight (close to 3 bills) I should be getting something with a lockout (which I have no idea what that ACTUALLY is, but I assume it locks the front suspension out from moving). I should also consider disc brakes to stop me (again, no idea about these... are there pads involved in disc brakes? When they say 'hydraulic brakes' are they really fluid activated like a car? are there containers for the hydraulic fluid?
I plan on using the bike about 80% on the street and 20% or less on grass and dirt.
I don't really understand the differences in the frames or components either.
Component wise, the two units seem similar
Differences
Frame
RH - M4 manipulated alloy frame, butted ORE DT, forged dropouts w/ replaceable 98954020 alloy hanger, disc only
HR - A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger, disc only
Fork (I have no knowledge of shocks. We were all still riding hard tail and hard forks when I stopped)
RH - RockShox Dart 3 SL, 100mm, 28.6mm Cr-Mo stanchions and alloy steerer, magnesium lower, coil spring, reb. adj. w/ lockout and preload adj.
HR - SR Suntour SF7-XCM-HLO, 100mm, 12": 80mm, 30mm Hi-Ten stanchions and steerer, coil spring mcu w/ preload adj., hydraulic LO, spring assisted seals, custom paint/graphics, disc only
Handlebars (not sure what this means)
RH - Specialized alloy 31.8mm XC rise, 620mm wide, 8 degree back, 8 degree up sweep
HR - Specialized alloy 31.8mm, Enduro rise, 640mm wide, 8 degree back, 8 degree up sweep
Pedals (not sure which is better...)
RH - Steel cage, composite body, 9/16"
HR - Specialized alloy platform, 9/16"
Rims (Are these the same wheels? eyelets?)
RH - Specialized/Alex RHD 26, double wall, for disc brakes
HR - Specialized/Alex HRD 26, double wall disc w/ eyelets
Tires - (not a huge issue as I'm going to replace either of these with either Maxxis Holy Rollers or Hookworms)
Front Hub (I don't understand what that number and the h mean)
RH - Specialized Hi Lo disc, 28h, CNC flange and disc mount, polished races, alloy QR
HR - Specialized Hi Lo disc, 32h, CNC flange and disc mount, polished races, alloy QR
Saddle
RH - Specialized XC, kevlar sides, front and rear bumpers, 143mm width
HR - Specialized Aggro, kevlar sides, front and rear bumpers, 143mm width
Everything else is the same
HEADSET - 1 1/8" threadless
STEM - Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
TAPE/GRIPS - Specialized Enduro, dual density Kraton
Brakes - are these any good?
FRONT BRAKE - Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
REAR BRAKE - Avid BB-5, mechanical disc, 6" G2 Clean Sweep rotor
BRAKE LEVERS - Avid FR-5
Transmission - Are these good bits?
FRONT DERAILLEUR - Shimano Altus FD-M310-6, top swing, 34.9mm clamp
REAR DERAILLEUR - Shimano Alivio RD-M410
SHIFT LEVERS - Shimano Acera SL-MC40
CASSETTE FREEWHEEL - SRAM PG-830, 8-speed, 11-32t
CHAIN - KMC X8, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET - Shimano FC-M341-8, replaceable rings, Octalink Spline
CHAINRINGS - 42S/32S/22S
BOTTOM BRACKET - Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 126mm for 50mm chainline
REAR HUB - Specialized Hi Lo disc, cassette, 32h, CNC flanges and disc mount, polished races, alloy QR
Rockhopper Disc
Hardrock Pro Disc
Differences
Frame
Saddle
