crank feen said:
When looking for an upgraded fork, is that all you have to take into consideraton, is the travel?
Generally no, some be look for more adjust-ability for instance
crank feen said:
What about the steering tube length/size?
If you're buying used, then yeah, steerer tube length is important......if you're unsure, generally you'd want a steerer the same length as your current fork.... from the factory the steerers are shipped long and usually get cut down to the needed size..
on the size of the steerer, that's a either it fits or not question, e.g. what is your frame/headset designed for...e.g. 1", 1-1/8", 1-1/4", 1-1/2", tapered.....
