I sure would appreciate some advice. I recently upgraded my nine year-old to a brandnew 24" columbia mountain bike. The bike has a front triple and seven cog rear. The drivetrain is all shimano except for MAX grip shifts.
Everything seems to work well but my son has a lot of difficulty in shifting for both the front and rear. He says he can't get the shifters to twist and when riding next to him, I see him struggling. He's experienced with the shifter as his previous 20" specialized six speed was similar where he had no shifting problems.
I can't figure out what's wrong. The routing looks fine with no binding or tight spots. I've tested and even folded myself up for a spin around the block and found no problem. For me it shifts fine but I'm significantly bigger and don't consider my effort a fare comparison.
Is there something I should look at or should I investigate another shifter. I've found 7 speed shimano STX trigger style shifters that I thought might shift easier but then I'm starting to wonder if the problem could be the dérailleurs and maybe these are what I should look at replacing or maybe the entire drivetrain.
Anyway, my son was excited to try and ride some trails but is now disappointed with this bike. I would appreciate suggestions.
Thanks,
Doug
Thanks,
Doug
