Bajamike said:
That looks great. I may have to try that as well. Does it ever move around on you?
Yes/No
I use a rubber shim that came with the mount to use as a anti-slip pad between the stem and the mount. Under normal riding conditions the gps remains in place. I use the GPS Map 60CS which is a bit bigger and heavier, I think.
Very rarely, it might slip a bit to the side after tackling a long rock garden at high speed but I just grab it and move it back. The trick is to get the zip ties tight.
To date, I have had the GPS come out of its cradle only once and that was because a mangled the cradle from transporting the bike. In all my crashes, it has not come out yet. For safety's sake, I loop the lanyard around the bars so if the GPS unit does somehow break free, it does not run away and get lost.
Besides, you can the the mount for $20.00, customize it to fit your bike, and worst case scenario, screw it up royaly and be out $20.00. It is not going to damage your bike or GPS.
After using this mount for over 3 years, I highly recomend it.:thumbsup:
